This thing`s killin` me...
Stan(PA)
10-05-2005 11:52:13
Two questions on 1951 Massey Pony....
1) What holds the throwout bearing on the release slide? My bearing slips on easily. Should it be a pressed fit?
2) Release slide (?) assembly is wallowed out some, and a bit sloppy on the shaft. Should I bush the shaft, or bush the hole in the release slide?
Lesson I have learned: If you don"t know what you are doing, it takes quite a while to restore a tractor! I"m posting this on "tractor talk" also, in case all you guys are hanging out over there.
Thanks,
Stan
jjcomp77
10-06-2005 07:12:22
 Re: This thing`s killin` me... in reply to Stan(PA), 10-05-2005 11:52:13
Yes it presses on the release slide not very hard though. maybe the last 1/4 inch.As far as slide being sloppy. findout which piece is worn, if it's slide bush it. if it's the tube replace it. hope this help a little John
parts man
10-05-2005 15:05:21
Stan, short answer is, sounds like you need to replace your release slide.
Stan(PA)
10-05-2005 15:23:40
 Re: This thing`s killin` me... in reply to parts man, 10-05-2005 15:05:21
Where can I get a new one? Is the throwout bearing definately pressed on? Sure do appreciate any information. Thanks.....Stan
parts man
10-06-2005 16:08:09
 Re: This thing`s killin` me... in reply to Stan(PA), 10-05-2005 15:23:40
Stan, yes the TOB is pressed on, a good tractor supply store should be able to get you a new one (maybe), or I have good used ones here. I will need the casting# off your old one to match as there are a couple of different ones for a Pony.
petetx
10-06-2005 16:06:31
more like a bump fit than a press fit
