massey harris 33 hydraulics
Tokyo
10-04-2005 15:38:07
continential e201 gas
need to find hydraulic pump and gear..
which drives off of gear under oil cap filler and housing.
(what that gear is???)
Thanks George
phillip d
10-04-2005 17:50:40
 Re: massey harris 33 hydraulics in reply to Tokyo, 10-04-2005 15:38:07
Hi Tokyo.If you can't find one any closer to where you live try D&M tools ltd in pei can at 1-902-859-3887 and ask for Dennis.If he doesen't have one than i'm not sure who will as he has nearly 100 antique tractors with several 33's parted out.If you call him,tell the MENNACE Dwayne Phillips sent you. Best of luck.
marlowe
10-04-2005 16:22:52
gear and pump are all one you can't remove the gear from the shaft. if i recall it's the same as a 44 pump
