Try again...
Stan(PA)
10-04-2005 07:49:54
I"m reposting this, because I know someone out there has the answer....
Where does the clutch return spring hook up on a 1951 Massey Pony? Mine was "rigged" when I got it, and I`d like to know proper mounting. I"m talking about the spring for clutch pedal. Thanks...Stan
Dave_Id
10-04-2005 08:59:08
 Re: Try again... in reply to Stan(PA), 10-04-2005 07:49:54
Stan, I looked on my Pony last night, and mine didn't have any. (1948)
Stan(PA)
10-04-2005 09:52:47
 Re: Try again... in reply to Dave_Id, 10-04-2005 08:59:08
Dave, mine doesn"t have one either, but both tractors SHOULD have one. Parts book shows part# J1493, 3/4 in diameter spring. I want to get one that"s close, but I"m not sure where it should attach. I was hoping someone on the forum would have a picture, or maybe a good explanation of attachment points..... Stan
Massey Harris Guy
10-04-2005 11:13:33
 Re: Try again... in reply to Stan(PA), 10-04-2005 09:52:47
Stan, On my 1951 Pony the spring is attached to the rod that goes from the pedal to the clutch lever. There is a hole about 5" from the clevis for the pedal with a cotter pin stuck through it and bent over. The spring is attached to the pin through the hole and to the bottom of the pedal. If you would like a picture I can do that too. Just let me know.
Frank
