180 massey hydralics
hayes hill
10-03-2005 20:10:30
I was disc mowing everything worked when I finished. Iwent to raise my mower by remote hyd. I found that they would not work as well as I had lost multi-power,lft arms still function tractor has indpendent PTO it seemed to work fine as I was mowing, I almost have top plate off trans to split am or do you think I am going wright direction??? any input would be helpful.
had to leave mower behind to limp 180 home help.
Bob N.Y.
10-04-2005 17:07:23
 Re: 180 massey hydralics in reply to hayes hill, 10-03-2005 20:10:30
The main pump supplies pressure for the 3ph. The auxilary pump operates the IPTO, multi-power and remotes.
marty g.
10-04-2005 04:49:04
Disc mowing must have warmed up the tractor, after it cooled down, did the hydraulic come back? If hyd. comes back when cooled, try replacing safety relief valve and put new fluid in it. The relief valve is accessible from top cover.
The top plate will not give you access to the main hyd. pump. Tractor has to be split in front of tranny to get access to pump.
