Looking for good suppliers of used MF parts
Dick Nyquist
10-03-2005 04:04:14
Hello
Can anyone out there recommend some good suppliers of used parts? I"ve got A MF50 with a crack in the final drive housing just below where the top cover that has the lift arms bolts on. Is this a common problem with these tractors? Can these be welded?
Thanks
Dick
Our Farmer
10-03-2005 04:58:31
 Re: Looking for good suppliers of used MF parts in reply to Dick Nyquist, 10-03-2005 04:04:14
I guess it would depend on where the crack is, how large it is and what stresses caused it in the first place, but I have had good success welding cracks in cast with the following method. Use a nickel rod, and preheat the area with a torch. Use a stitch tecnique when welding, doing small areas for short periods to keep the heat down, then cover with a blanket so the repair cools slowly to minimize cracking. Among several other things, I repaired the lift cover on my 65 this way years ago and have had no trouble with it.
