motor i d
mgeod
09-29-2005 10:22:37
Ok here is a dumb question , I need to know how to determine my engine type . I have always thought it was a perkins tractor ser is 9 A I05053 , found these numbers on the engine block , these are casting number 3711150012. also ckn1842 , there is some other number on the other side of the motor but I will have to get them was headed out to work and will have to remove some dirt and grease to get them , thanks
Big Dean
09-29-2005 11:58:13
 Re: motor i d in reply to mgeod, 09-29-2005 10:22:37
What is model number on the tractor? With that serial number it should be a for a tractor built in 1970. If it has a diesel engine it would be a Perkins. If it has a gas engine it could have either a Perkins or Continental.
mgeod
09-29-2005 21:28:19
 Re: motor i d in reply to Big Dean, 09-29-2005 11:58:13
it is a 135 and its a deisel . Thanks Big Dean , I thought it was but wasnt sure
Big Dean
09-30-2005 10:43:58
 Re: motor i d in reply to mgeod, 09-29-2005 21:28:19
That would be a Perkins AD3-152 direct injection engine they have a rope type rear crankshaft seal prior to engine serial number 152UA391046DL engines with that serial number and above have a rubber lip seal. Other than that there has not been any changes in them to speak of.
