MF 235 Steering
Ernie(Wa)
09-27-2005 23:14:41
How much up/down play is normal MF 235 steering wheel? I have heard that one inch means the steering box is junk. Would 1/8 to 3/16 inch be considered normal? Then how would you adjust the ball & sector gears? Thank you.
Big Dean
09-29-2005 12:30:15
 Re: MF 235 Steering in reply to Ernie(Wa), 09-27-2005 23:14:41
If it has power steering then 1/8 to 3/16 is probably about right it needs some up and down movement to move the selector valve. The only adjustment on them is the side plates that the sector shaft come out of have slotted holes where they bolt on to the steering gear. Twisting them one way moves the sector gear towards the ball nut the other way moves it away from the ball nut It has been so long since I worked on one of them I don't remember for sure which way is which. They don't move much though. Hope this will help some.
Ernie(Wa)
10-03-2005 10:29:03
 Re: MF 235 Steering in reply to Big Dean , 09-29-2005 12:30:15
Thanks Big Dean.
