Starter smoke
Don H
05-25-2000 06:52:09
I recently bought a MF 150 (1969) and everything works fine except for the starter. The previous owner had allowed the fuel pump to seep diesel and soak the starter. The rubber seal around the hot wire that goes from the solonoid into the starter motor has turned to mush. The starter works fine but there is about a 2 foot diameter cloud of smoke emitted from inside the starter at start-up. The smoke doesn't smell electrical. Any ideas?
Jack in NB
05-27-2000 03:45:24
 Re: starter smoke in reply to Don H, 05-25-2000 06:52:09
Hello Don -
Fix it - fast.
That smoke is trying to tell you something - "Where there's smoke, there's fire" - and it's right under the fuel pump if it flares up.
It may just be residual fuel inside the starter, but still needs immediate attention.
The starter is expensive, but the whole tractor is a lot more valuable!
Good luck.
Jack
