MF 65 crankshaft oil seal.
Culla
05-25-2000 04:55:37
I need to replace the oil seal on both ends of the crankshaft. Will this job requires the removal of the crankshaft from the engine block.?
Thanks.
Culla
Wayne Winsted
05-25-2000 06:30:04
 Re: MF 65 crankshaft oil seal. in reply to Culla, 05-25-2000 04:55:37
I have replaced the crankshaft seals in my MF 65 but it has been a while. No you don't have to remove the crankshaft. To replace the rear seal you have to seprate the tractor between the bell housing and the engine. It's not necessary to pull the oil pan either.
Culla
05-25-2000 21:53:05
 Re: Re: MF 65 crankshaft oil seal. in reply to Wayne Winsted, 05-25-2000 06:30:04
Thanks Wayne.
Culla.
