Gerald, Bob M Thanks If it ever stops raining I will give it a try. Let you know how it worked on Monday. THANKS : : : : Just got the TO 35 I am rebuilding started today - first time in 15 year it has run. New battery,etc. I am stumped though - the amp meter is reading negative - the faster I run it the more negative it gets. Could something have gotten reversed? Is the generator not working (how do I check gnerator output??)? Ideas! Thoughts! : : : : Thanks : : : : Bob : : : Hi, : : : I also have a 35 and I think that you need to polarize the voltage regulator. The way to do this escapes me at the moment but the instructions are in the box with a new regulator. My dealer just took the instructions out and handed them to me. Perhaps you will be so lucky. : : : Could alsop be that you just reversed the wires on the amp meter. : : : Chip : : Hi Chip, : : We tried polarizing the generator yesterday and that did not make a difference. Since generator technology is a little old no one around here seems to know how to take a voltage or AMP reading off the generator. : : Anybody have the instructions on how to perform a Voltage or AMP reading from a generator?? : : Bob : There should be two terminals on the generator. One larger than the other. The small one is the field connection (goes to the regulator), the large one is the output from the generator. You read generator voltage from that large post to chassis. It should match the polarity of the battery. If it doesn't you have troubles. If the generator IS charging, the voltage at the generator should be a little bit higher than the battery voltage. That's one check. I often use an ammeter made to check generators, alternators, and starter currents. It has a couple guides on its back, a big one for starter cables and a smaller one for other circuits. It can be confusing about direction of current, but checking the voltage at the battery and the generator isn't. There will be a little voltage drop in the wiring between the generator and the battery and you should be able to detect that to see if the generator is charging. The most optimum charging voltage for a 12 volt system is 14.2 volts. Higher will overcharge the battery, lower will undercharge the battery. Half that for a 3 cell battery. : The positive terminal of the ammeter should be wired away from the battery, e.g. the negative to the battery, providing the negative post of the battery is grounded. Just the opposite if the battery positive post is grounded like my 4020 gas.
