power steering ?
in sticks
09-18-2005 17:14:33
have a 135 that has a Cessna power steering pump on it.problem is NO POWER STEERING.pump just seems to circulate fluid through control valve/ steering box.checked control valve and cleaned and checked for leaks reassembled according to big deans cd to make sure things were right side up,checked lines to make sure they were on proper inlet and outlet positions.have proper travel in vertical on steering wheel.should mention when bought tractor power steering did not work,was missing pump and steering box was a mess. when turning wheel engine does not change rpm ,sounds like no load.need help.any ideas appreciated TIA
