MF 130 ?
Jay 2NSC
09-17-2005 18:48:25
just thought I would run this by you all and see if anyone now"s where we can find part"s for it or should we sell it for part"s? Thank you for any suggestion"s. Jay 2NSC
lynne wilson
02-25-2006 16:44:01
 Re: MF 130 ? in reply to Jay 2NSC, 09-17-2005 18:48:25
I have one for sale. It is running. Had some work done on it to get ready for the season but found one a little bigger which is what I need. I had it two years and it has run well. It has 3 new tires, will need the 4th. Asking 3000. Will come with shredder. It will be good to use as is or to put the two together, or have parts for it later. If your interested email me. I live out side of Austin Tx. Lynne
phil25
09-18-2005 15:40:26
parts??? Well your 130 as i am told is the amercian/canadian version of the french 25, and a lot of parts are the same. I have yet to not be able to find things at a dealer that has the parts book to look things up, seems the book/numbers is the key to getting stuff for these odd machines? no number for a 130? check the 25 numbers, it worked vise versa also.
good luck.
Hey ,thanks phil25..Jay 2
09-19-2005 13:27:08
 Re: MF 130 ? in reply to phil25, 09-18-2005 15:40:26
I appreciate the info.I've been told it's French made and the part's are extremely hard to find. It's my father-inlaw's tractor. You wouldn't know how to adjust the clucth would you? Not sure how to tell if it is a 2 stage or not? Thank's again. Jay 2NSC
phil25
09-21-2005 17:33:01
 Re: MF 130 ? in reply to Hey ,thanks phil25..Jay 2, 09-19-2005 13:27:08
Well we can try to get you going:)
You should be able to feel the need to press a bit harder on the clutch to disengage the pto clutch, if not able to notice it don't worry.
With the pto in gear[ not ground speed] turning a speed of some rate, push the clutch ALL the way down[ pto stops] and put the tractor in a gear[ first/low range is good], when the clutch is released slowly, the pto shaft should begin to turn, before the tractor starts to move[ 2 stage clutch]. Better to have someone watch the pto when doing this so you don't generate paper work leaning back over the seat to watch.
To adjust the cltch remove the access cover in front of shift levers[ or in line with the clutch/flywheel area. There are three adjustments bolts that give the clearance between the operating lever and the throwout bearing contact. I have mine set at 75 thou clearance, although book [s] say different, i went with "big deans" advice, and suggest you make contact with him if in doubt or to check on my advice. He has a good cd available, thats covers a lot of tractors, and touches on ours also, worth the pennies to obtain.
Be sure to have the fuel stop lever in the STOP position before SLOWLY turning over the engine to bring the adjusting bolts up into position. Try not use the starter to roll it,as it tends to overshoot where you want it, a pry bar or likewise device works.
The actual pedal is adjutable at its securing location, loosen the bolt and with the rod to the throwout bearing turned fully Counter Clockwise, re-tighten the pedal securing bolt, so that the pedal is full up against the housing stop point. this gives about 1 to 1,5 inches of free travel before the throwout bearing touches the fingers, and you start to feel resistance against the pedal when pushing it down.
Remember this is a result of the distance you have set the finger clearance at via the 3 adjustment bolts.
Thats all i have, work[ed] for me, hope its of use, can't promise it will fix a totally gone clutch.
good luck
Bryan A. Meinert
09-28-2005 09:11:44
 Re: MF 130 ? in reply to phil25, 09-21-2005 17:33:01
Phil, I am the somewhat ashamed owner of a MF25. I am desparately searching for a grille for this tractor. Can you help??? Please... Bryan
