135 Gas Tank Cap
Homegrown
09-15-2005 19:30:11
Recently, I replaced my gas tank cap since the rubber seal was dried out and cracking. Now I notice that after sitting in the sun all day, or running the engine for a bit, the tank gets pressurized. Is the cap supposed to have a vent hole in it, or is this normal? Engine is the Continental Z-145 if it makes any difference.
Don-Wi
09-15-2005 21:28:58
 Re: 135 Gas Tank Cap in reply to Homegrown, 09-15-2005 19:30:11
We've got the same problems w/ our 165. we replaced the cap, and now if it hasn't been run and it's in the sun, the tank gets pressurized. It is vented, but it must have a check in it that prevents it from coming out for some reason. Never had a problem with it building up a vacume.
Donovan from Wisconsin
mowr
09-16-2005 19:54:08
 Re: 135 Gas Tank Cap in reply to Don-Wi, 09-15-2005 21:28:58
For a tractor it must be vented both ways. I bought a diesel tractor with a blown injector pump seal. You guessed it; someone had installed a pressure cap.
mowr
09-15-2005 20:26:59
Your tractor requires a vented cap. A non-vented cap (as used on modern cars) may fit but the pressure buildup could blow a line, filter, sediment bowl, perhaps even the tank. Some company has a free gas cap for certain tractors according to posts I've seen here on YT.
Willy-N
09-15-2005 20:20:23
Mine had a vent in it and never built up pressure. Mark H.
Homegrown
09-25-2005 14:42:17
 Re: 135 Gas Tank Cap in reply to Willy-N, 09-15-2005 20:20:23
Thanks for the responses.
