replace brake pads on massey ferguson 175
george henson
09-13-2005 19:50:44
need tips on easy way to replace brake disc.
george henson
09-15-2005 19:13:58
 Re: replace brake pads on massey ferguson 175 in reply to george henson, 09-13-2005 19:50:44
is it best to leave the rim on the housing or to seperate when removing it.
Willy-N
09-15-2005 20:30:12
 Re: replace brake pads on massey ferguson 175 in reply to george henson, 09-15-2005 19:13:58
Definetly remove the tire off the trumpet first. You do not want all that weight working against you when it comes apart. You could mess up seals, knock it off the blocks ect if things start to fall. You also have to pry it apart and sliding the tire would make it even harder to do. Mark H.
Big Dean
09-13-2005 20:50:09
Hi George Sorry but there is no easy way to replace the brakes on the MF175. You first must remove the tires and wheels then remove the axle housing the brakes are in the inside end of the axle housing. I have pictures that show how it is done. If you would like to have them email me with an email address I can send them to.
Willy-N
09-13-2005 23:04:27
 Re: replace brake pads on massey ferguson 175 in reply to Big Dean, 09-13-2005 20:50:09
Your right! It is not easy since I just did it to my Orchard that has disk brakes!! Once all the hard part is done the pads are easy to remove. Mark H.
george henson
09-15-2005 19:22:09
 Re: replace brake pads on massey ferguson 175 in reply to Willy-N, 09-13-2005 23:04:27
i have a massey 175.how do i know the exact size of the brake disc. i see different sizes and tooth count, just want to be sure before i take it apart.
Willy-N
09-15-2005 20:27:00
 Re: replace brake pads on massey ferguson 175 in reply to george henson, 09-15-2005 19:22:09
Not sure posibley you could find out with the Trumpet part number, serial number of the tractor and take that information to the dealer to have them look it up in there parts book. Mark H.
