Who needed the Reponce Control MF135 Dip Stick
Willy-N
09-13-2005 18:02:32
Someone asked me if I had the Cover Plate with the Responce Control (Right Side) for the MF 135 Orchard Tractor? I have one now and a lot of other parts off the Massey 135 Orchard Complete Rear End assembley like Planitary ends, axle shafts, pto shaft, disk brakes and parts, levers, hydraulic top plate, pump ect. I will tell you one thing lifting the Top Plate off a Orchard 135 is a bear!! It must weight 140 lbs or so. Removing the Trumpets with Planitary Gears is also a heavy part to deal with. I also must say these tractors are sure built STRONG inside compaired to a 8N tractor 3 times as solid is not out of line!! Mark H.
