Paint the block - what paint?
StL Bill
09-12-2005 12:47:28
Got all but the engine primed on my MF135.
What about the engine....what paint do I need. Is there special high heat primer? Will the same Flint Gray paint I'm using for the rest of the tractor work or do I need a high heat version of that too?
What happens if I just use the 'regular stuff'? How long will it last?
Appreciate your immediate reponse.
Dave_Id
09-12-2005 14:16:25
 Re: Paint the block - what paint? in reply to StL Bill, 09-12-2005 12:47:28
I painted the block on my 101 Senior with single stage urathane from Napa. It all held up well except the exhaust manifold burned off immediately after starting. You can use a high heat paint, but it'll probably burn off the manifold too, because it just gets too hot
Jason(PA)
09-12-2005 18:43:27
 Re: Paint the block - what paint? in reply to Dave_Id, 09-12-2005 14:16:25
Most paints I see hold up on engine blocks and still keep there gloss unless its something really cheap. As far as the manifolds go I been using Caterpillar muffler paint and its been staying on great. I have one tractot I use a good bit and its been on there for 5 years and it still lokks like I just put it on.
