MF65, hydraulic seems worn?
Jacob Petersen,
09-11-2005 13:27:41
I have a couple of questions concerning my MF65 diesel. I have been using it for around a year rebuilding a house and a barn. The tractor seems worn. The most of its life it has been used mainly operation a front end loader.
My question is, when having load on the 3 pt. lift I can hear some kind of �knocking sound�. The sound appears to be coming from the area around the clutch? When the tractor warms up performance on the 3 pt. decreases considerably. Could these symptoms be coursed by a worn oil pump? If yes, are the rebuild kits for oil pumps available for this model?
Furthermore it is not possible to engage the PTO even though the clutch is pressed all the way down. Shouldn�t the MF65 be equipped with a 2 stage clutch?
I appreciate your input, and I hope that your understand my simple DanishEnglish :-)
Jacob Laue Petersen
Denmark.
Big Dean
09-11-2005 21:23:16
 Re: MF65, hydraulic seems worn? in reply to Jacob Petersen, Denmark, 09-11-2005 13:27:41
Hi Jacob The three point symptoms you are describing sounds like one that needs the three point pump rebuilt. You can get a rebuilt kit for the MF65 from a few places on the Internet one place is this site Your PTO problem is probably the Internal PTO clutch adjustment needs to be made. It is up through the hole in the bottom of the transmission bellhousing. I have a picture with instructions on how to make the clutch adjustments. If you would like to have it send me an email address and I will email it to you.
