135 (1969)PTO ?
spudslite
09-11-2005 09:12:20
Not sure what the Ground position on PTO shifter does,Engine position engages rear PTO, I think I should get a manual. Is there anyway to get more downward pressure on hitch arms? I am using a blade to stripe top layer of grass,not working to good.
wolfman
09-12-2005 18:25:15
 Re: 135 (1969)PTO ? in reply to spudslite, 09-11-2005 09:12:20
Ground speed PTO was used for things like PTO rakes etc. You can hang a tractor wheel weight (with large center hole) over top hitch point of blade. Maybe a small chain to hold it.
spudslite
09-11-2005 20:26:10
Thanks for the response, I'll give it a try.
terry274
09-11-2005 13:10:32
Try tilting the blade and putting it at an angle so that it digs into the ground. After you get it ripped up, you can go back and smooth it out.
Cosmo
09-11-2005 10:28:53
The ground position on your PTO is practically useless nowdays. It turns the shaft in proportion to your ground speed; independent of the engine speed. You don't have downward hydraulic pressure. Additional weight is the option. HTH, Cosmo
XERXES
09-13-2005 04:10:14
 Re: 135 (1969)PTO ? in reply to Cosmo, 09-11-2005 10:28:53
The best thing i ever used my ground speed for was unclogging my round bailer.It works forward or backwards,You can put the tractor in reverse and just bump it backwards and it will loosen the haw on the roller so it pulls out easier.
