massey harris 44
leroy-trufant
09-10-2005 16:53:01
I HAVE A 1951 MASSEY 44, WHEN EVER I TRY TO START IT MY POSITIVE CABLE GETS HOT VERY QUICK, IS THIS A POSITIVE GROUND SYSTEM? I WOULD LIKE TO CONVERT IT TO A 12 VOLT SYSTEM, OR SHOULD I LEAVE IT A 6 VOLT? ANY INFO ON WIRING IT FOR A 12 V OR LEAVE IT ALONE WOULD BE GREATLY APPRECIATED,
THANK YOU
royston cradock
09-12-2005 11:50:27
 Re: massey harris 44 in reply to leroy-trufant, 09-10-2005 16:53:01
Hi Leroy
moving onto your question 6V or 12V,to change, you would need to change the following items,
starter , dynamo, voltage regulator, ign coil, and condensor. these would all need to be 12V. yes 12V is better as it will have more cranking power the original 6V system.tends not to be as troublesome either, as 6V isvery dependant on GOOD EARTH, and CLEAN contacts. hope this helps
royston
royston cradock
09-11-2005 11:42:36
Hi Leroy, fault is probabley two fold.1)battery cables not heavy enough, 2). more likley poor earth, try taking earth straight to starter.6V systems on MH tractors were pron to earthing problems,as i have found for myself.
ROY
leroy-trufant
09-11-2005 15:02:13
 Re: massey harris 44 in reply to royston cradock, 09-11-2005 11:42:36
tried a 2/0 battery cable on the pos. side, had ground attached tostarter hold down bolt, then my neg cable burnt, and starter started smoking, should i leave it 6 v or change over to 12v?
royston cradock
09-12-2005 11:38:35
 Re: massey harris 44 in reply to leroy-trufant, 09-11-2005 15:02:13
HI Leroy
you had a sugestion on another follow up that you might have a 12V starter instead of 6V. If this was the case then the starter would work but only at half speed with not much guts (sluggish).I would personally , remove the starter and bench test it first. this is easily done by connecting neg (-) to casing and pos(+)to feed terminal.if motor spins freely then i would look to the starter bendix, ensure it is free to spin and move up and down on shaft. A thought has just come to me,are you using a remote starter selenoid or has your starter got a starter handle going to the top of the starter like the old 745 model
roy
Kevin Bismark
09-11-2005 18:10:53
Are you sure something isint locked up, a 2/0 cable should be okay, how bad of shape is the starter in now, if you got smoke out of it it might not be for the long haul, and are you sure you don't have a 12 volt starter in there, things have a tendancy to get changed around on these old tractors, they get sold and no one knows what they are working with...
jjl
09-11-2005 05:55:04
Yep, sounds like a battery cable issue. Make sure your new one is a 0 or 1 gauge. You cannot use those light gauge automotive type on a 6 volt system.
msb
09-10-2005 18:29:42
Replace the battery cable .Probably badly corroded underneath the insulation where you can't see it.
