1150 clutch plate service limits????
rkgordon
09-10-2005 15:05:19
I have the tractor in half and before I put it back together, I would like to know what would be considered minimum pad thickness on the clutches. I have a service manual but cannot fine this information in it.
Thanks.
marlowe
09-10-2005 19:02:35
 Re: 1150 clutch plate service limits???? in reply to rkgordon, 09-10-2005 15:05:19
spend a little now or a lot more later if it's in half change it out
rkgordon
09-11-2005 04:07:27
 Re: 1150 clutch plate service limits???? in reply to marlowe, 09-10-2005 19:02:35
I broke the tractor in half because the ipto shaft stop pin was broken and allowing the ipto shaft to move forward out of a coupling between the transmission and the rear housing. The clutch was working fine at the time. I agree it would be easy to change now, but for all I know the clutch thickness may be fine now. Do you know what the thickness of a new clutch pad is?
