MF-265 Lift Arm End Replacement
Pete Schueler
09-10-2005 11:13:46
The lower lift arm end part# 184462M92 (cat. 2) on the left side broke off at the hole where a through-pin attaches it to the lift arm bracket. I've ordered a new one but I can't remove the pin from the bracket. The pin goes through holes on each side of the bracket and the lift arm end. The lift arm end goes inside the bracket and has a spring-loaded release that allows the end ball to swing up. The through-pin has a fine threaded lug nut on the inside of the bracket and a shoulder with a stub shaft on the outside of the bracket that attaches to a stabilizer bar with a lynch pin. There seems to be a bushing on the pin inside the bracket. I've got the lug nut removed but the pin won't budge after liberal doses of blaster, heat and 4# hammer blows. Have I missed something holding this pin or what? I assume the pin is a removeable standard part because you can't install a new lift arm end without removing it. HELP!!!! All advice gratefully accepted.
marlowe
09-10-2005 13:43:15
 Re: MF-265 Lift Arm End Replacement in reply to Pete Schueler, 09-10-2005 11:13:46
are you talking about the pin that holds the end if the lift arm to the tractor?if so you have to pull the trumpt the pin has a nut on the in side
