Two Pony questions??
Stan(PA)
09-09-2005 13:11:25
1) Where do the headlights mount on the Pony?
2) How do you change the battery? Do you have to remove the steering arm, and then the left side panel?
Okay, that was 3 questions, but one was a two-parter! Thanks....Stan
51Pony
09-11-2005 06:32:42
 Re: Two Pony questions?? in reply to Stan(PA), 09-09-2005 13:11:25
Stan,
The left side curtain has a slot cut out of the curtain to slide down over the steering arm. That's so you don't have to remove the arm. At least that's the way this '51 is.
Stan(PA)
09-11-2005 07:50:29
 Re: Two Pony questions?? in reply to 51Pony, 09-11-2005 06:32:42
Mine"s also a 1951 Pony. It has no slot, just a round hole. Maybe I"ll cut a slot, it sure would make things easier in the future. Thanks...Stan
KenSWLA
09-09-2005 18:22:39
1. Mine are attached to the lower hole on the radiator support.
2. Just remove the left panel and the battery hold down.
Stan(PA)
09-10-2005 06:38:35
 Re: Two Pony questions?? in reply to KenSWLA, 09-09-2005 18:22:39
Thanks Ken. One more question... how do you remove the left panel without removing the steering arm? My steering box shaft goes right through a hole in the panel. Thanks....Stan
KenSWLA
09-10-2005 10:10:43
 Re: Two Pony questions?? in reply to Stan(PA), 09-10-2005 06:38:35
I don't have any of my Ponys here but the way I remember them they have a cut out that goes over the steering arm that lets the panel go over the steering arm. If you don't have an answer soon I will let you know next week.
Ken
kevin currie
09-16-2005 02:37:00
 Re: Two Pony questions?? in reply to KenSWLA, 09-10-2005 10:10:43
I have two ponys a 52 & a 49 and they have slots for steering arm but u still have to take arm off to get panel off. The lip of panel is behind the dash edge and does not allow u to pull it out with steering arm on.
