MF 150 external hyd. spool
farmerscotty
09-08-2005 06:27:44
I have neighbor with a mf 150 gas older one with continental gas engine.
He has a 2 valve spool attached kinda under the seat and is using one side of the spool for his little loader to make it go up and down. he has to have the other lever pulled back and locked to use the 3 pt arms. He wants to add another hydralic cylinder to his loader so he can kurl his round bale on the front of the loader. What does he need to do to be able to do this? if he hooks into the valve will his 3 pt arms still work? does he need to change something. I have a picture of the valve to show anyone that wants to see it. I had a valve on my 165 but it had an extra lever to lock to use the 3 pt arms when you were not using the valve for the loader. he doesn"t have that. Other problem is he cannot get the hex screws loose to take the valve off so he is kinda stuck.
Any help would be appreciated. He is a great neighbor.
If you want to see the valve I have pictures I can send.
Scott.
Big Dean
09-08-2005 11:52:00
 Re: MF 150 external hyd. spool in reply to farmerscotty, 09-08-2005 06:27:44
The best way to do that is to add an another two spool valve for the loader. I have a diagram I can send you on how to hook it up that way. He can also lock the three point arms where they cannot move either by chaining them or built a T bar to connect to the lift arms on the bottom and the top to where the three point top link hooks. Then he can use the left spool. If I can be of further help on this Email me
