Quick detach loader on MF135
KW
05-04-2000 12:36:37
I'll press my luck with yet another MF135 question on my "new" tractor. I looked at the quick detach loader and it looks very easy to detach, with the two spring loaded pins at the rear. As far as the hydraulics, do I detach the pump along with the loader ? The only other option I can see is to disconnect the hoses at the pump, which would bleed the system. I've heard of quick disconnect fittings, and was wondering if this might be a smart investment for me to make for the two hoses connecting to the pump so that I don't need to detach the pump every time. Or is the pump supposed to come off in order not to damage it doing other things ? Also, in order to clear the front axle when backing away from it, I'm assuming I need to park first under a stout limb of a big tree or something similar to be able to hoist it up ? The only reason I can see where I'd remove the loader is for plowing and disking in some damp areas of my property. The front loader makes it front heavy and reduces the traction. Thanks for your indulgence !
