hydraulic filter
taper
09-06-2005 21:21:19
where is the hydraulic filter on a 85 massey ferguson gas about a 1960 model 4cyl. thanks
willL
09-07-2005 16:37:50
 Re: hydraulic filter in reply to taper, 09-06-2005 21:21:19
It is actually more of a screen than a filter. It is under the square plate held on by four bolts by your left leg when sitting in the seat. If your transmission is full of oil all you will see is the top part that holds the "filter" to the intake of the pump. This top part unscrews and you can then lift out the "filter". Sometimes this top retainer is wired to the pump to keep it from coming loose. It is sometimes hard to find the hole when putting it back in if the transmision is full of oil. It helps to have small hands in there!!
