Our company ON & SE has been in production and sales of metal enjection molds and aluminum , zamac and other metal alloy die casting products since 1990 in the Republic of Turkey in the city of Konya . Production range: - metal enjection moulds - tractor parts - various automotive parts - And other required parts and products We give our production which are about on tractor engine parts directly tractor factory(TUMOSAN) which is located in konya Turkey. And other parts for local marketings and export other countries (direct & indirect) as after market goods..We also can respond die casting products for cutomers according to samples or drawings. Our machinary range: A) for casting : In our company, at once we can cast up to 7,5 kgs. aliminium and zamac alloy with hot and cold chamber metal injection presses. Our casting machine range : -1/1000 toned cold chamber metal injection press ( it will be soon.. in 3-4 mounths) -1/850 toned cold chamber metal injection press ( it will be soon.. in 3-4 mounths) -1/400 toned cold chamber metal injection press -1/350 -toned cold chamber metal injection press -1/200 toned cold chamber metal injection press -1/150 toned cold chamber metal injection press -1/100 toned cold chamber metal injection press -1/50 toned hot chamber metal injection press Operation after casting: If it is required, it is possible to give surface cleaning, shining and shaving with vibration, work with CNC machines and other shaving procedure could be given.
Our machine range (park) for after casting procedure: - CNC - Shaving vibration - Drills - Tape sanding machine B) for mould : The metal injections patterns are desinged in cad-cam programmes and made on CNC vertical operators. Moulding Machine range (park) : - CNC vertical operator - Electrolytic erosion - Tos lathe - Universial lathe - Moulding cutter - Horizential cutter - Radial drilling machine - Surface grinding - Grinding of holes C) quality and laboratory : - ISO 9001 - CAD - CAM - 3D coordinate measuring equipment - metal microscope - hardness measuring equipment - and other measuring & testing equipments We are willing to work with your esteamed company. Thanking you in advance for your valuable time and hoping to hear from you soon . B. Regards IHSAN KUCUKHUYUK Foreign Trade ON & SE Mould and enjection Die Casting Contact Details : person : IHSAN KUCUKHUYUK ( mobile) 0090 536 4485522 address : Busan Ozel Organize Sanayi 4. Sk No: 18 KONYA / TURKEY Tel : +90 332 345 07 55 - 56 Faks : +90 332 345 01 83 e-mail : [email protected] Web : www.onse.com.tr under construction..... .
