Serial # for Pony
GKU41
09-05-2005 19:43:08
I bought a pony and need help verifying the serial #. This number is stamped in the housing under the left side of the seat: G6D(or O) CANADA 850095 M8 (M-H)
Is this the serial #, and if so, what year is it? Was the tractor made in Canada? Thanks for any help someone can provide.
Jerry
GKU41
09-06-2005 19:24:28
 Re: Serial # for Pony in reply to GKU41, 09-05-2005 19:43:08
Thanks Stan for the info. Will check it out
Stan(PA)
09-06-2005 06:38:37
Mine is 850095 M11, but that is the part number for the transmission case. The serial number is on a plate, located on the engine support, on the right side, below the fan area. It may be painted over, or missing. The serial number should start with PGS (standard axle), or PGA (adjustable front axle). By the way, I"m pretty sure that all the Pony`s were made in Canada. ....Stan
kevin currie
09-16-2005 02:45:00
 Re: Serial # for Pony in reply to Stan(PA), 09-06-2005 06:38:37
serial number plate is on right side side frame under engine.If it is not there 49 and older pony have rounded draw bar new ones have square draw bar.
