pony generator
Dale n.
09-04-2005 09:43:24
I have a pony, I think is 51 or before, I can't get the generator to work. it has 1 pole and 1 wire coming out of generator. How do you hook it up. it is getting hot. I have painted the tractor and I can't see the model number. Thanks for any help. Dale
dale n.
09-05-2005 13:04:31
 Re: pony generator in reply to Dale n., 09-04-2005 09:43:24
51 pony, I would like to talk to you if you would send your phone number. Thanks so much, Dale
51Pony
09-04-2005 17:16:38
Dale,
The generator is 6 volt positive ground if it's an original installation. Is the meter showing anything? I have a diagram I can send you if it will help.
Dale n.
09-05-2005 12:57:36
 Re: pony generator in reply to 51Pony, 09-04-2005 17:16:38
Pony 51, Yes I would like to have the wireing diagram. Thanks you so much. Dale
Larry R
09-05-2005 06:55:50
OOps I meant 51 Pony on the wiring diagram ! Larry
Larry R
09-05-2005 06:53:31
Dale I would like to have a copy of the pony wiring diagram if you could send it ! Thanks Larry
