Massey 35 Diesel with 24 volt system...
David Montgomer
05-03-2000 23:44:04
I bought a Massey 35 Diesel. Is this normally a 12 or 24 volt system. It has two batteries but don't know if they should be in series to make 24 volts. Also, is a common tractor and is it generally considered a good tractor. It smokes alot when first started then stops and needs a little starting fluid to get going. What do you think?
twopop
05-04-2000 05:43:04
 Re: Massey 35 Diesel with 24 volt system... in reply to David Montgomery, 05-03-2000 23:44:04
The MF 35 is a good tractor,and in my opinion much better than a ford."I believe in green" but for a smaller size tractor,it is a good all around unit.It should be setup as a 12v system.As far as the fuel goes,sounds like the first stage pump in ther injection pump is weak,however it could need new fuel filters.Which engine do you have?is it 3 or 4 cylinders.One fellow i know has a electric fuel pump ahead of the injection pump to stp the problem your taling about.
