444 ?
Dale L
09-03-2005 11:06:27
Does anyone know the oil capacity of a 444 is and what grade of oil is recomended? Thanks
Steve Ruhmann
09-03-2005 19:49:46
 Re: 444 ? in reply to Dale L, 09-03-2005 11:06:27
Parts store should know what filter you need, but don't bet on it. You get a green counterman and you will have to hold their handto find it.
MARLOWE
09-03-2005 12:00:49
CAPACITY OF WHAT ?
Dale L
09-03-2005 12:30:05
 Re: 444 ? in reply to MARLOWE, 09-03-2005 12:00:49
Whoop's The engine oil of a MH 444.
marlowe
09-03-2005 15:12:22
 Re: 444 ? in reply to Dale L, 09-03-2005 12:30:05
well i use 15-40 series 3 diesel oil in every engine i have from the lawnmower to a 903 cummins.cars, trucks, motorcycle,t0-20 fergusons [5] and my 44 special [same engine] as 444. that way no mix ups or confusion . i think it's 6 q with filter but just check with dip stick
Dale L
09-03-2005 17:47:34
 Re: 444 ? in reply to marlowe, 09-03-2005 15:12:22
Marlowe thanks for the input. I pulled the top of the oil filter canister and there was no filter in it . That's not a good sign! Oh well the parts store should know what filter goes in it.
buss
09-04-2005 07:03:58
 Re: 444 ? in reply to Dale L, 09-03-2005 17:47:34
I think it is 1090 napa filter
Dale L
09-04-2005 09:54:45
 Re: 444 ? in reply to buss, 09-04-2005 07:03:58
I just called napa and they came up with the same number. They have to order it. The tractor has been sitting under a tree on a potato farm for who knows how long. I'm going to pull of the valve cover and make sure the valve train is loose and change the oil and gas. Cross my fingers and crank it over and hope she fire's. Thanks for the input.
Harlan Thomas
11-06-2005 03:58:58
 Re: 444 ? in reply to Dale L, 09-04-2005 09:54:45
I am trying to find steering parts for a 444 with tri cycle front end. I have a parts diagram but it does not say what the part is called. It is a piece about 3 in. long and has threads on the out side and spline teeth in the inside. It is listed as part number 15. It goes into the steering box and it also has a small pin that goes through the side of it. If anyone has any ideal what this is called and where I might find one I would really appreciate it. I saw you were discussing a 444 and just was hoping maybe you or someone could give me some information on this. Thanks.
masseymaniac
09-04-2005 13:26:05
I have a Massey Harris 333 it takes 8 qts with a filter change. The WIX filter is#51010. I use 10w30.
