Front End Loader, Forks Bucket done! Picture
Willy-N
09-02-2005 17:47:12
third party image
All I have left to do is cut a few points off the Upper Forks Mounts, hook up the Control for the 2 Tilt Cylinders, hoses are all in waiting for it. Then I need to give it a coat of paint! Forks slip out of the Bucket with 2- Grade #8 Bolt & Nut on each, real easy to do. It was a bear to get those Forks Mounted even so they would be solid & strong plus easy to remove. I have 2 sections of 3/8" steel behind the top bolt welded into the bucket forming a V and then gusteted to the bucket. Lots of weld at that point and it is in front of the Tilt Cylinder mount brackets on each side. That way the bucket can't flex or bend. The lower bolt goes thru the bucket and Main Loader Mount for the Arms backed up with steel plates to keep it sucure and tight against the bucket back. I put 2 plates on the bucket bottom to add strength and 2 knobs on each side of the them to keep the forks from getting knocked side ways. Now I can leave the bucket on all the time. I made the Bucket, Cross Member and Tilt Cylinder Mounts from scratch and figure I have around $300.00 total into the project. Now I can have a great weekend the Major work is done! Mark H.
Willy-N
09-02-2005 18:40:19
 Re: A Little different angle view in reply to Willy-N, 09-02-2005 17:47:12
third party image
This is a better view, I was tired and did not take any more pictures. Mark H.
DavidP, South Wales
09-03-2005 10:02:04
 Re: A Little different angle view in reply to Willy-N, 09-02-2005 18:40:19
Hi Mark,
Looks like an absolutely excellent job. Can I make a suggestion that will certainly prolong the life of your loader. From what I can see in the photo, the bucket ram pins appear to be going through just the plate thickness each side which I assume is 7/16 (10mm) or maybe 1/2 (12mm). Even in this thickness the pins will elongate the holes and cause slop in the setup. I would suggest turning up some collars to weld on the outside of the plates to give the pins a bigger 'footprint' and reduce wear. They can also be drilled through for a pin to retain the ram pin. I assume that the ram ends already have the provision of a grease nipple.
Cheers
DavidP
Willy-N
09-03-2005 13:32:53
 Re: Another picture with Hay on the Forks now. in reply to DavidP, South Wales, 09-03-2005 10:02:04
third party image
Note the picture is how I will transport the Bales low to the ground so there is no way it can roll back on me or hurt anything if it falls off.
I plan on welding Harden Collars on all the joints that don't have them yet. The Loader Arm tips have had there bushings replaced with 1"inside X 1 3/4" outside X 3" long solid bushings allready. Just was waiting till I knew for sure what size and how many I needed to buy. All the pins are harden steel ones. I will put grease zerks in all the moving points that do not have them yet. I raised the forks up all the way and tilted them level. I was able to have them 9 feet off the ground level! I also need to cut all the points off the Gussets and add a couple more on the forks for side movement strength. After all this is done I will blast it clean with my pressure washer and sand and paint it. Been a fun project to work on! First time working with Hydraulics and building something like this. Mark H.
DavidP, South Wales
09-04-2005 04:52:51
 Re: Another picture with Hay on the Forks now. in reply to Willy-N, 09-03-2005 13:32:53
Hi again,
Well done. It's essential to have greasing points. As an interested onlooker I am very pleased to see that you are going to cut off the points from the gussets (and any ugly corners). It's pleasing to the eye and means the difference between a 'welding job' and a 'PROPPERJOB' (spoken in a broad Devon accent).
Keep us informed of progress.
DavidP
Willy-N
09-04-2005 08:34:00
 Re: Another picture with Hay on the Forks now. in reply to DavidP, South Wales, 09-04-2005 04:52:51
When I started this job I thought it would be real easy to do. I find it was a lot of work but now it is time to finish it right. Don't want it just cobberd up! Got the points off last nice, lot of grinding on the Torch Cut edges!! Mark H.
Willy-N
09-03-2005 13:46:48
 Re: Another picture full 9 ft level height. in reply to Willy-N, 09-03-2005 13:32:53
third party image
This is all the way up and the forks level. Mark H.
Willy-N
09-03-2005 07:30:56
 Re: Close up of the fork mount in reply to Willy-N, 09-02-2005 18:40:19
third party image
I still want to add 2 gussets on the sides of the lower mounting plate welded to the forks to give them more strength for side ways Twist movement. Nothing stays on the bucket on the lower mount and I will flush the upper mount on the bucket with the fork since it stays on the bucket. Mark H.
