M.F. 135 Wiring etc.
J.J.inB.C.
08-29-2005 15:45:54
just purchased M.F. 135 Diesel ser.# 3810 can it be possitive ground, are wiring harness available, does anyone have a wiring diagram,what year is it ???
jrsn
08-30-2005 00:53:22
 Re: M.F. 135 Wiring etc. in reply to J.J.inB.C., 08-29-2005 15:45:54
JJ , That number could be a UK 135 from 1965. There are a lot of UK built massey"s here in Canada. Is there a SN plate on the dash.? Is it the 3 cyl. Perkins engine. If it is UK built it will have LUCAS electrics. We have a "73 135 with Perkins. A great tractor. Ray -s,also in B.C.
J.J. in B.C.
08-30-2005 20:26:03
 Re: M.F. 135 Wiring etc. in reply to jrsn, 08-30-2005 00:53:22
Thanks guys, yes Ray it does have a plate on the dash thats where i got the number,it is also a Perkins diesel, everything on the tractor says made in England. I would still like to know if its supposed to be possitive ground. J.J.
jrsn
08-31-2005 19:50:22
 Re: M.F. 135 Wiring etc. in reply to J.J. in B.C., 08-30-2005 20:26:03
JJ, I went out to the farm and looked at our 135UK.It is Neg. ground. BigDean on this site has a lot of info photos at "http://pg.photos.yahoo.com/ph/bigdean63/my_photos" There are some wireing scematics there. #7 picture is diesel with Generator. Ray-s..
Willy-N
08-29-2005 18:20:59
Make your own if you have some bad wires just replace them. Unless you are going to show this tractor nothing hard about following a wire and replacing it with a new one. Only real set bak is some wires go into jacks and you will have to splice new wires onto them and it looks like you fixed it not replaced it. Search the arcives with MF 150 and things come up and read all the different questions and answers you will find lots of good information on them. Check the Serial number section for years of tractors on this site to the left. Mark H.
Willy-N
08-29-2005 18:22:42
 Re: M.F. 135 Wiring etc. in reply to Willy-N, 08-29-2005 18:20:59
I ended up answering 2 posts in one! The 150 search was for above post. Sorry, Mark H.
