MF 135 oil leak
Harry Nolting
08-29-2005 10:31:24
I have a 135 that leaks oil from the mounting plate for the tachometer. There is a hole approximately 1/16" in diameter in the plate leading out in a downward angle below the tachometer connection. Oil has started spurting out of that hole. #1 Why is there a hole through the tach mounting plate? Is it a vent hole, and what is supposed to keep oil from leaking out?
#2 Why did it just start leaking within the last year?
#3 I plugged the hole to stop the leak. Will that cause other problems?
Willy-N
08-29-2005 14:16:12
 Re: MF 135 oil leak in reply to Harry Nolting, 08-29-2005 10:31:24
You can see the hole and seal in these pictures. Mark H.
Big Dean
08-29-2005 12:28:18
That hole is a weep hole so the oil leaking past the seal in that plate does not work it's way up the cable into the Tach it's self. You remove the plate and replace the seal in it. Over the years the seal will dry out and get hard from the engine heat this causes them to start leaking.
