To All MF88 Buffs!
William Neideff
08-24-2005 16:52:19
third party image
Well after going though eight states calling probably 90% of the resources and into Canada and back into Michigan i just wanted to let you all know that there is still everything available for the Massey Ferguson 88. Just takes a lot of work tracking the stuff down.
William Neideffer
08-24-2005 17:06:04
 Re: To All MF88 Buffs! in reply to William Neideffer, 08-24-2005 16:52:19
third party image
See if i can get the photo to work.
Roy in UK
08-26-2005 22:40:07
 Re: To All MF88 Buffs! in reply to William Neideffer, 08-24-2005 17:06:04
Is that tractor next to it jacked up on bricks? yikes! Been a lot safer using blocks of wood e.g. cut down railway sleepers.
marty g.
08-25-2005 05:17:12
Is that a compressor sticking out on the side of the 88's. Is that another 88 in the work besides the nice one?
William Neideffer
08-25-2005 10:12:46
 Re: To All MF88 Buffs! in reply to marty g., 08-25-2005 05:17:12
No, not a compressor. It's a vaporizer retro fit i did. And yes that's another 88 in the works. If was the 5th one off the assembly line. Serial #880005.
marty g.
08-26-2005 05:22:56
 Re: To All MF88 Buffs! in reply to William Neideffer, 08-25-2005 10:12:46
Ah I see. I'm not familiar with LP engines, excuse my ignorance. I guess it vaporizes the gas before going in carburator. Very nic tractor by the way.
jorge negrete
08-25-2005 13:21:44
Looks like your MF88 is LP, if so could you tell where the water outlets are located on your engine. I have an LP F40 and I can't find Water outlet/inlet. I only have a Vaporizer which is locate in front of Engine, which I'm replacing with a Two Stage Converter, however I can't find water outet/inlet.
William Neideffer
08-25-2005 16:07:25
 Re: To All MF88 Buffs! in reply to jorge negrete, 08-25-2005 13:21:44
If you'll send me your email address i will scan the service manual page for mine and send it to you. Maybe that would help.....don't know how alike the 85 and 88 are to your F40. But the 88 use to have it's vaporizer mounted in water pump cavity. Let me know.
Jorge Negrete
08-30-2005 06:38:35
 Re: To All MF88 Buffs! in reply to William Neideffer, 08-25-2005 16:07:25
my email is ([email protected]). I need all the help I can get. My F-40 also has the Vaporizer mounted in water pump cavity however, I don't have any idea where or how the Regulator would be mounted/located and secondly, my biggest problem water outlet/inlets. I can't seem to locate them. Thank you, jorge
