MF 135 pto
Fred Mills
08-24-2005 14:07:19
I can't get my 1974 mf 135 to go into engine speed pto. It slips easily into ground speed pto. When I try to engage the engine pto it is like the clutch isn't depressed. Any idea what might be wrong?
supergrumpy
08-25-2005 07:42:17
 Re: MF 135 pto in reply to Fred Mills, 08-24-2005 14:07:19
might check external clutch adjustment on side of tractor first, Big Dean has all the info you need
if tractor has been sitting, maybe some rust on the clutch face, with engine off, put PTO in engine gear with decent implement load on the PTO, start engine and then stomp on the clutch to see if you can break it free or polish some of the rust off
if oil contamination on the clutch lining, might require splitting the tractor to correct
Fred Mills
08-25-2005 09:42:59
 Re: MF 135 pto in reply to supergrumpy, 08-25-2005 07:42:17
Thanks to everyone for your responses.
The suggestion to really depress the clutch worked great.
Big Dean
08-24-2005 16:24:34
There is an Internal adjustment for the PTO clutch that you make up through the hole in the bottom of the transmission bellhousing It sounds like it may need to be adjusted If you will send an email address I have a picture that show how to adjust the Pedal free travel and the internal PTO adjustment I will email you
Willy-N
08-24-2005 15:43:49
Are you sure you are completely pushing the clutch in all the way down? The 2 stage clutch requires more forse to disengage the PTO Clutch after the Engine one is. Mark H.
Fred Mills
08-24-2005 16:59:21
 Re: MF 135 pto in reply to Willy-N, 08-24-2005 15:43:49
Thanks for your responses. Yes, I think I am pushing the clutch all the way in. I'll Really push hard tomorrow just to be sure.
Willy-N
08-26-2005 20:38:31
 Re: MF 135 pto in reply to Fred Mills, 08-24-2005 16:59:21
I have to push mine to the Running Board to work the PTO. The Engine does not require it to be pushed as far and much easier to do for shifting. Mark H.
