Rear axle seal on Massey 22
RJJ
08-23-2005 18:58:41
I am new to Massey Harris tractors so please forgive my common questions. First I have a leak on one of my rear axle seals. It is leaking out of the hole under the brake housing. I am sure that I will need to remove the wheel, the outer axle break housing. Can the seal then be removed and replaced on the outside by sliding out past the brakes and off of the axle and do I need any special tools? Second I need to replace the front drive shaft seal. Can I just remove the drive shaft, remove the large nut on the transmission and pull the seal out the front of the transmission? Any advise before I tackle this job would be greatly appreciated.
Thanks.
