MF135 transmission/hydraulics fluid ?
KW
05-03-2000 08:55:43
I just picked up my "new" MF135 and I am going to change the transmission/hydraulic fluid. On my Ford 8N, I always used 80/90W transmission gear oil from Central Tractor. Is this the same fluid to use in the MF135 ? or does it take something else ? How much does it hold ? Also, is there a filter that needs changing on these ?
Bob
05-03-2000 17:32:42
 Re: MF135 transmission/hydraulics fluid ? in reply to KW, 05-03-2000 08:55:43
The 80/90 is way too heavy. I use Texaco TDH oil-claims to meet the MF specification. Clean the screen on top of the pump when you have it drained.
Takes about 8 gallons if memory serves.
Bob
Big Dean
05-03-2000 13:29:57
The original Massey # was M1129A it changed to Perm A Tran 3 it is about a 30wt. oil. If you buy another brand just make sure it is an extreme pressure oil or there will be excess wear to your gears.
