1150 no hydraulics at all.
rkgordon
08-19-2005 17:43:19
Does anyone have a transmission schematic that can be emailed? I just took the charge pump out hoping that I would have a sheared key or something similar since I have nothing hydraulic. It appears to be ok, but the gear that turns the charge pump gear spins freely on it"s shaft. I don"t know if it should or not. I just got the tractor and am unfamiliar with it. This is the first place I started. Thanks.
rkgordon
08-20-2005 06:16:19
 Re: 1150 no hydraulics at all. Need help. in reply to rkgordon, 08-19-2005 17:43:19
I have ordered Service and Parts Manual, but would like to work on tractor now. I feel like I will probably have to break tractor, but would like to see what I am in for before doing it. Any advise on possible problem would be greatly appreciated.
Rednight (IL)
08-20-2005 07:06:31
 Re: 1150 no hydraulics at all. Need help. in reply to rkgordon, 08-20-2005 06:16:19
third party image
Is this what you are after? I have sent you an email.
rkgordon
08-20-2005 08:58:30
 Re: 1150 no hydraulics at all. Need help. in reply to Rednight (IL), 08-20-2005 07:06:31
Thanks, but that is not what I am looking for. I need a schematic that shows the gear and shaft that mates to the charge pump in the transmission housing.
Thanks.
Rednight (IL)
08-20-2005 10:08:17
 Re: 1150 no hydraulics at all. Need help. in reply to rkgordon, 08-20-2005 08:58:30
third party image
Maybe this be the one !
rkgordon
08-20-2005 11:22:33
 Re: 1150 no hydraulics at all. Need help. in reply to Rednight (IL), 08-20-2005 10:08:17
That is what I am looking for. Thanks a lot. The IPTO Clutch (9) spins freely on the shaft in my tractor. What should it be doing? How does it turn the charge pump? I am guessing either it should not be turning freely on the shaft unless the coupler (12) or something else causes it to engage when the tractor is running. Thanks in advance for any other info you have.
Cod
08-23-2005 19:02:53
 Re: 1150 no hydraulics at all. Need help. in reply to rkgordon, 08-20-2005 11:22:33
Item#10(IPTO Shaft) might be twisted off. This shaft fits into the end of crank via a splined connection.
