135 P/S
tolo61
08-17-2005 18:26:41
Recently rescued a family 135 from salvage. Runs great, but the first problem is the power steering. The pump pumps and has fair power steering action. Problem is that the gear box vent over flows power steering fluid and it is foamy. Should I be using something other than ps fluid, or is there something else going on?
Tim
GaryF
08-19-2005 17:20:14
 Re: 135 P/S in reply to tolo61, 08-17-2005 18:26:41
There is a piston and rack arrangement contained in the housing on the rear of the steering box. This is where the vent you have mentioned is located. Most likely cause of loss of fluid is oil bypassing piston rings. This is a common problem with this type of PS system you may be able to get by honeing the cylinder and replacing the rings. You need a manual that covers this repair. You should also check pressure at outlets of the control valve. It's mounted on the steering shaft the manual should cover this test. Most of the TDH oils meet the MF spec for this application. However you should check.(I use it in mine)
