MF 135 Rear Differential has Locked Up?
Eric Johnson
08-16-2005 15:48:33
Posting this message to help my father-in-law. He has a MF-135 (64-66 model), gas engine, 2WD. Recently, after reaching operating temperature, it seems as though the rear differential is locking both rear axles together. The rear wheels both drive and will not allow the tractor to steer (The front wheels turn fine, but the tractor continues straight ahead). This happens in high/low, forward/reverse and every gear. Anyone have any idea why this would be happening? Thanks for any and all help.
Willy-N
08-16-2005 16:45:34
 Re: MF 135 Rear Differential has Locked Up? in reply to Eric Johnson, 08-16-2005 15:48:33
You may have had some damage accure inside the spider gears in the center of the differential that have locked them up. That would be my idea unless a rivet or something off the ring gear got into the spiders. Mark H.
in sticks
08-16-2005 17:29:34
 Re: MF 135 Rear Differential has Locked Up? in reply to Willy-N, 08-16-2005 16:45:34
DOES THE TRACTOR HAVE A POSI LOCK? MAYBE IT IS STUCK IN POSI? CHECK FOR FOOT PEDAL ON RIGHT REAR UNDER THREE POINT CONTOLS
Roy in UK
08-16-2005 22:33:13
 Re: MF 135 Rear Differential has Locked Up? in reply to in sticks, 08-16-2005 17:29:34
I second that, it is so easy to accidentally put your foot on that pedal, they have a nasty habit of sticking down too.
Eric Johnson
08-17-2005 16:44:44
 That was it Fellows - Thanks in reply to Roy in UK, 08-16-2005 22:33:13
It turned out to the the Posi-lock level. The bolt that hold the lever had worked it's way loose and the level was flopping into the locked position.
Thanks again for all the help!
