Oil filter savings
diesel 35/135/65/165...
Jack in NB
05-02-2000 09:34:33
The spin-on oil filters on these and other MF diesels with the Perkins 152 through 203 engines (MF 1447 082M1) is the same as a Wix 51460 or Fram PH2895. However, before using Fram check this site:
Link
Quality probably doesn't make a difference if you change the filter at every oil change.
There's a cheaper spin on - about 1/2" shorter and 1/4 the price: VW rabbit/golf gas. Wix 51318, Fram PH2870A, AC PF 56.
The earlier cannister filters are tricky to install correctly - internal springs loose or missing, and gasket leakage. That entire assembly can be replaced with the later spin-on filter head (741 922M1) for under $20 US.
My $.03 (Cdn, = $.02 US!)
Bob
05-03-2000 17:46:48
 Re: Oil filter savings - diesel 35/135/65/165... in reply to Jack in NB, 05-02-2000 09:34:33
You were reading my mind!! I was just getting ready to replace that troublesome cartridge filter affair!
Thanks for the details,
Bob
