mf 65 right brake no work.
duke jennings
08-13-2005 19:08:27
i have a mf 65 tractor and when i apply the right b rake the linkage moves but the brake no works. i have the rear right axel pulled to check for wear and am unabe to get to the brake shoes to see what the problem is. need some help here as i am lost on how to seperate the outer hub to get to the brake shoe assembly. thank you for your help. duke
Big Dean
08-16-2005 12:00:12
 Re: mf 65 right brake no work. in reply to duke jennings, 08-13-2005 19:08:27
Hi Duke The MF65 has dry disc brakes they are in next to the differential housing. You stand the axle housing up on the lug bolts there are two screws that holds the big plate with the axle seal in it on to the axle housing. Remove those two screws and lift off the big plate. The brakes are below that plate there are two disc and the actuator that applies the brake in there. If I can be of further help email me
2x4
08-15-2005 23:40:43
Is there a big screw in the front of the hub? They make a special 1/2 square socket to fit a 1/2 inch breaker bar but probably a big screwdriver will back it out. Then gently tap the hub rim & it should pop off. CRC sprayed on will help.
