MF 65 Oil Pressure
Greg A
08-10-2005 05:43:48
What is normal and minimum engine oil pressure for a MF 65 gas. My tractors oil pressure at operating temp. and RPM is 15-17 psi at idle it drops to 10 psi, is this to low of oil pressure.
txgrn
08-11-2005 08:35:43
 Re: MF 65 Oil Pressure in reply to Greg A, 08-10-2005 05:43:48
Yeah. Try a higher viscosity oil B4 you do anything drastic....like 15w-40 truck diesel type oil..Wally World house brand is ok. Or if you are a purist you could select from Shell Rotella T, Chevron Delo, or Mobil Delvac....of the same viscosity.
Then if it'is still low, it could be a gauge or you could be in for a new set of engine bearings (crank mains, push rod inserts)....or maybe an oil pump.
Mark
