to35 gas dies after reaching op. temp restarts am
rdwango
08-09-2005 14:42:56
have a to35 gas, that dies after reaching operating temp. if i let it sit for 1 min it will restart and run for 5 min, let it rest for 1 min, runs for 5 min ect... i have replaced spark plugs, rebuilt the carb.,replaced the thermostat, the cap,rotor,points and wires look great, any ideas ???
tg in VA
08-11-2005 15:33:00
 Re: to35 gas dies after reaching op. temp restarts in reply to rdwango, 08-09-2005 14:42:56
I had the same problem with my TO35, it was the ccoil. Another time it would run a short while, quit, start again after I waited a few minutes and repeat the process (just like Big Dean wrote). My problem was the filter at the carb end of the fuel line. I blew it off/out with the air hose and have had no more problems.
Sure was frustrating before it dawned on me to check the fuel line as it entered the carb.
Big Dean
08-09-2005 20:13:23
I wrote this article to go on my web site on what I have found causing that problem I will some day get it on the web site. I get ask this question more then any other questions on those old tractors. I wrote this article to put on my web page I will get around to it some day. Hope it helps you Big Dean Two things most likely cause your engine problem.
{1} There is a restriction in your fuel system. You are not getting enough gas though to keep up with what the engine is using. When you shut of the engine the carburetor bowl fills up. Think of this as a carburetor reservoir as the engine is using more gas than is getting to the bowl after a while the engine will use all the gas in the bowl and the engine stops. When you shut the engine off and let the bowl fill up the engine will run again till it uses the gas in the bowl again. The most common places for a restriction are in the tank shutoff valve. According to which valve your has. Some have a screen inside the tank it will plug with trash that accumulates in the bottom of the tank this is usually rust. The other valve without the screen the trash will stop up the opening where the inlet in the valve gets smaller the valve has to be removed from the tank to clean these places. There is also a screen on the elbow inside the carburetor that the gas line connects to that stops up if your still has the original elbow. If yours has a settling bowl on the shut off valve it should have a screen in the top of it that will also plug up. The harder you run the engine the quick the engine will stop. This problem is very common on a gravity fed fuel system. {2} the coil will sometimes short out inside when the coil gets hot causing the engine to stop as soon as it cools off the engine will run again till the coil gets hot. This is a little rare but I have run across it quite a few times through the years
Big Dean
08-09-2005 20:12:06
I wrote this article to go on my web site on what I have found causing that problem I will some day get it the web site. I get ask this question more then any other questions on those old tractors. I wrote this article to put on my web page I will get around to it some day. Hope it helps you Big Dean Two things most likely cause your engine problem.
