mf150 3 point wont go up all the way
John R Sr
08-04-2005 13:49:56
From what i have been told is that i have a mf 150 with a 3 point hitch, i have a york rake on it it was working fine then it stopped working it only goes up enough until it has full wieght of the rake on it.it has hydo fluid in it any help would be great. Thank You
Nigel G
08-06-2005 06:08:03
 Re: mf150 3 point wont go up all the way in reply to John R Sr, 08-04-2005 13:49:56
Hi John, Not sure what a york rake is, but it sounds heavy. If the hoist lifts ok without the rake on and makes the pump rattle on constant pumping position I would think the fault could be the adjustment of the draught spring, or a broken draught spring. This is the spring in the housing infront of the top link mount. Remove the top link, grasp the yoke and check for foward/rearward play. Should be zero.Good luck.
Big Dean
08-05-2005 08:42:58
Hi John The first thing that come to mind is a standpipe O-ring or the O-ring under the lift cylinder but it could be the relief valve. If it happened all at once. If I can be of further help email me.
