MF 200 hydraulics
Greg
05-01-2000 15:49:38
On a MF 200 equipped with a front-end loader, does anyone know the GPM of the hydraulic pump?
Reason; I have a MF 220 backhoe and I want to use a Prince 540 PTO hydraulic pump to power it. They offer a 11.4 and a 20 GPM pump. I want to get the one that is closest to the pump on the MF 200 because this is the tractor that the backhoe was designed for.
Also looking for hydraulic control handles for the backhoe, dealer says they are obsolete.
Thanks for reading.
Anton
06-21-2000 14:12:06
 Re: MF 200 hydraulics in reply to Greg, 05-01-2000 15:49:38
I too have a MF 220 backhoe and want to use a Prince PTO pump, the 1000 though. I would like to know what psi and flow I should run the hoe at. I will be mounting it to a TD-6.
Jim Weaver
05-01-2000 19:31:55
Greg I have an MF 200 with 6 way blade and tried to look it up in my manual but no luck. Would you know of someplace to find out what the oil and fuel filter numbers might be. Or a place that specializes in MF parts? Thank you.
Jack in NB
05-02-2000 03:49:42
 Re: Re: MF 200 hydraulics in reply to Jim Weaver, 05-01-2000 19:31:55
Jim -
What do you have for engine? What do the oil and fuel filter(s) look like?
The filter combos are fairly standard; may be able to help sort it out for you with the above info.
Jack
Jim Weaver
05-02-2000 07:01:08
 Re: Re: Re: MF 200 hydraulics in reply to Jack in NB, 05-02-2000 03:49:42
Jack, I have what the book calls a AD3.152, Which I believe is a 152 cubic inch 3 cyl diesel. It is the best little diesel engine I have ever encountered. I am not sure what year however. Any help on the filters would be great. Thanks Jim Weaver
Jerry Cline
09-17-2004 20:07:36
 Re: Re: Re: Re: MF 200 hydraulics in reply to Jim Weaver, 05-02-2000 07:01:08
Jim,
We have a MF200 that we purchased from my father, can you tell me what year(s) the 200 dozer was made? Also the left steering lever occassionaly
does not work, we have to use the brake and pull back on the steering lever before the dozer will turn. Any ideas of what the problem may be?
Any and all help is greatly appreciated.
Jerry
arthomas
09-06-2005 07:26:27
 Re: Re: Re: Re: MF 200 hydraulics in reply to Jerry Cline, 09-17-2004 20:07:36
rust on steering clutch plates. that is what coused my tractor to break the final drive shaft.i'm steel looking for parts to fix mine.
A.R.Thomas
08-25-2005 11:36:20
rust on steering clutches.will break final drive if not fixed.do you know of any dismantaled tractors.this is what happened to mine.
David mulkey
09-05-2005 14:16:35
 Re: Re: Re: Re: MF 200 hydraulics in reply to A.R.Thomas, 08-25-2005 11:36:20
I have a (1978) MF200 i am going to sell. IF interested E-mail [email protected]
