44-6 shifter
Jim - Illnois
08-03-2005 07:03:23
The shifter in my "new" 44-6 has been broken at the rubber boot and welded a steel rod to it. When I unbolt the shifter bace, is there any springs that will come flingin out and take me the rest of the day to figure out where they came from? Any hints? Thanks.
STUDIEdiesel63
08-04-2005 08:56:51
 Re: 44-6 shifter in reply to Jim - Illnois, 08-03-2005 07:03:23
Assuming all you want to do is change the shift handle,just pull the boot up and pop out the little snap ring,the shiter will then pull right out.
msb
08-03-2005 14:35:20
Remove the top cover the shifer is located in and you won't have to worry about dropping anything into the transmission.
