How do you add a hydr. hose to mf 65 gas
julius
05-01-2000 14:31:57
Wondering how to hook a hydr. hose to run a cylinder just a one way cylinder would be fine thanks julius
Clarence Carhill
05-01-2000 19:09:08
 Re: How do you add a hydr. hose to mf 65 gas in reply to julius, 05-01-2000 14:31:57
You have to purchase a selector valve that mounts on the transmission case below the seat between yor legs. Then you will need a control valve to control the oil to your remote cylinder. This can be mounted over on the right fender. The sad thing about the older M-F hydraulic systems is... you cannot use your three point hitch while using your remote clyinder...
