mf178 leak???
fromky
08-01-2005 09:01:14
I have a 178 with a leak around the selector valve for the aux. line. I noticed that there was not any type of gasket between the selector and the tractor and was wondering if this is my problem? This is the valve right under the seat and to the right. Thanks in advance.
TomTX
08-01-2005 11:12:09
 Re: mf178 leak??? in reply to fromky, 08-01-2005 09:01:14
I had a similar leak on my MF-690,and it was small o-rings around the poppet valves. Replaced them and end of leak. It was quite a job: had to pull out one of the long bolts holding the "slices" together, since it went through the poppets to hold them in. The old o-rings were dried up and loose; the new one were very tight when re-inserting the poppet valves. Do you have the MF Repair Manual?? I needed it for my repair.
DavidP, South Wales
08-01-2005 09:51:30
Hi,
There should be a recess in the underside of the valve body to accommodate an 'O' ring part number 195 561 M1
DavidP
