Hydraulics on a MF 130
Don H
05-01-2000 13:04:37
I have a 1976 MF 130. The lift settles in a few minutes with no load and if hot will barely lift a 7ft mowing machine. The lift will lift 1,000 lb. hay bales cold but I really have to rev the motor up when hot. Is there an easy fix? I had a similar problem with an 8N Ford. All I had to do was replace the pressure release valve and all was OK. Thanks for any help.
